View Full Version : Correct screw orientation ?
Agu
07-17-2009, 07:01 PM
Replaced all the outlets and switches in my house with the help of an electrician friend. Could have done it myself but with an older home I wanted to have him confirm everything was done right and up to code. He did find and correct some questionable wiring, for which at some time he'll call in the favor. In the future he'll have me helping him on some really miserable job and I'll have to smile and pretend I'm enjoying myself. ;)
After we finished I replaced all the switch plates with new plates.
After a few weeks he came by and informed me all my plates were installed wrong. All the screw slots holding the plates were up and down (perpendicular to the floor). He informed me all screw slots should be horizontal (parallel to the floor).
So who's right and why?
The answer that we're both anal retentive with compulsive personalities is not correct btw .
Speedy Petey
07-17-2009, 07:08 PM
They MUST be on a 45 degree angle. This is extremely important. I have seen whole houses fail inspection because of it.
This can be found in the district code addendum XR7-4Jc.
Please don't make this mistake again. ;)
jimbo
07-17-2009, 07:13 PM
It has to do with the way that electromagnetic flux lines "leak" off the head of the screw. If you put the screws in wrong, it will cause interference on TV's and computers.
Speedy Petey
07-17-2009, 07:30 PM
And birth defects. Don't forget birth defects!!
Agu
07-17-2009, 07:32 PM
Does that have anything to do with the belief that loose electrons will collect in a horizontal screw slot ?
Agu
07-17-2009, 07:39 PM
BTW, I understand painters have their own rules. Their technique is to tighten the screw until the plate cracks, back off a half turn, and blame the electrician.
Bobelectric
07-18-2009, 12:56 AM
Balance,We need Balance!
Billy_Bob
07-18-2009, 06:38 AM
I should think you would want to verse yourself in the various aspects of
Screw Theory by Sir Robert Stawell Ball...
Screw Theory...
http://en.wikipedia.org/wiki/Screw_theory
http://upload.wikimedia.org/wikipedia/commons/e/e6/Sir_Robert_Ball00.jpg
07-18-2009, 08:49 AM
quote; Screw Theory...
Isn't that the motto of most handymen? As for the original question. Throw the screws away and glue the plates to the wall. The screw holes will allow air circulation to prevent heat buildup in the boxes. By the way, did you check the screw orientation on the ones holding the wires?
jbfan74
07-19-2009, 10:49 AM
Screws always up and down!
This allows the dust to fall from the screw to the floor where the cats have something to play with!
07-19-2009, 02:09 PM
Wrong! If the slot is up and down, the dust does not accumulate. Horizontal it will build up until it gets heavy enough to collapse, and then the cats will have a large ball to play with. Why are you still using slotted screws? Phillips will eliminate the uncertainty.
PEW
07-20-2009, 09:01 AM
No one covered the summer to winter rotation requirements.
I always do mine late spring and late fall when I change the air in my tires. Makes it easy to remember.
Jeff1
07-20-2009, 09:04 AM
What about the Northern vs Southern Hemisphere adjustments for vortex and magnetic differentiation?
Agu
07-20-2009, 07:08 PM
I live in SW Florida, do those requirements also apply in subtropical climates? I thought that only applied in climates where the cold caused shrinkage?
