View Full Version : squeaky outside faucet
anon125
07-17-2009, 06:29 PM
Our outside taps are cold resistant. that is the washer part is about 10 inches inside the house.
they squeak when you turn them.
what do we oil them with - without damaging the washers?
thanks
anon125
07-20-2009, 09:42 PM
somebody must know the answer!
Cass
07-21-2009, 06:54 AM
While I am not 100% sure my guess is the noise is coming from the packing nut area right behind the handel...you could try turning it left 1/2 a turn then tightening it back 3/4 of a turn and see if this makes a difference..
anon125
07-21-2009, 08:32 AM
thanks we will try that
anon125
07-21-2009, 07:07 PM
Some freeze proof hose bibbs have a "loose fitting" spacer piece inside the tube, in order to keep the sealing washer centered on the seat when it closes.
http://www.arrowheadbrass.com/op_champarrow/graphics/orderportal/Arrowhead_Repair_and_Part_Kits/PK80xx_4.jpg
You can see on this arrowhead replacement stem, it's a square shaped metal piece right next to the washer (on the right side of the picture.) In my experience, this metal spacer "squeaks" when turning on and off the hose bibb, and make some odd "fluttering" noises when water is flowing, from the metal spacer inside scraping & vibrating inside the metal tube.
I don't know if your hose bibb has a loose fitting metal spacer inside it as well, but if so that might be the source of the squeaks.
http://www.arrowheadbrass.com/op_champarrow/graphics/orderportal/Arrowhead_Repair_and_Part_Kits/PK20xx_4.jpg
I happened across this picture, which looks like it's got a rubber spacer (maybe also a backflow preventer...) which would surely be more quiet than the metal spacer.
PS - I have the arrowhead hose bibb with the square shaped metal spacer and although a bit noisy, it does work very well. (It has a really strong water flow.) Hope this info helps.
thanks
it only squeaks when we turn the handle...
