Charles2000
07-16-2009, 02:19 PM
Hi all,
I think this is a simple question, but after scouring this forum and others, I'm suprised at not finding an answer. Briefly, I can simplify one section of my DWV layout if I can place a toilet directly on the top of one 3" column of DWV soil stack. That is, no closet bend, just a straight drop from the flange down 8 ft. of stack through the basement.
I'm suspicious because I've never seen such a layout illustrated or discussed. I can't imagine any reason, laws-of-physics-wise, arguing against it -- but in plumbing that's how many a false step is made :-)
In detail the vertical stack would have a 3x3x2" SanY underneath to vent the toilet followed by a 3x3x2" SanT for the shower drain (already vented). At the bottom, 3X4" bushing and a 4x4x4 SanY with cleanout. This then connects through a combo to the 4" main drain line out to my septic system. This stack is at the terminal end of the main drain.
I think I'm a capable amateur, I've, er, advised and passed inspection on a larger and more complex system for a friend's place in the same county. This question regards my own (under construction) house.
Thanks for your consideration,
Charles
Charles
