Hello,
I have a duplex where the cold water shutoff valve started leaking after I used it. I noticed on here that you can try to tighten the packing nut to see if that fixes it, and if not, you need to replace the valve. I will try tightening the nut first, but since it's a ways away from where I live, I figured I'd do my other research ahead of time. My problem is, I don't have any more upstream valves to shut the water off with. I noticed there is a valve on the other side of the water meter that looks like it's in worse shape (I don't want to try turning that off for fear it will start leaking too). Is there some sort of valve that you can screw onto 3/4" copper while the water is still running through it? My guess is no, because I don't see how that would be possible, but I figured it wouldn't hurt to ask. Any other ideas for me? Thank you for any advice you can give,
Ben
Ben
