View Full Version : garbage disposal height
A0159072
07-13-2009, 04:42 PM
Help! I have a question about locating my GD on the deep side of
a double sink during a kitchen remodel.
Is it OK for the outlet of the GD do go DOWN through a trap and back
UP to a T and another trap -- as long as the GD outlet is above the final trap??
I want to connect just like the picture located at
http://www.easy2diy.com/cm/easy/diy_ht_3d_index.asp?page_id=35743512
but I want to make sure it will not backflow into my GD. This picture seems like the shallow sink drain can flow into the deeper sink drain through the GD.
Thanks !
Tom
07-13-2009, 04:52 PM
The tutorial is wrong.
It shows the drain being higher then the disposer.
How would you expect it to drain up?
With most deep sinks, the drain from the wall needs to be 16" from the floor or lower.
http://terrylove.com/images/sink_dw.jpg
A0159072
07-13-2009, 07:20 PM
Terry - yes that is what I thought (diagram is wrong). Can I come straight out of the GD to a T or do I need to use a 90 to go down? That would buy me a few precious inches to keep the GD above the trap.
Thx, Tom Becker
07-14-2009, 06:04 AM
That tutorial is what happens when you give unqualified people access to the Internet. That is about the WORST way a disposer could be connected, and if the opening in the wall is above the disposer outlet, there is NO way to make it drain properly. But if it is higher, then the usual "disposer continuous waste" will do it properly, without using the elbow which comes with the disposer.
A0159072
07-14-2009, 10:23 AM
thanks for the help!
FloridaOrange
07-14-2009, 10:57 AM
I had to go and look at that web page. Hahahahahaha
