bath fixtures
cdd1204
I currently have Moen shower/tub fixtures (they are in a chrome finish - Chateau collection). I looked for this particular "model" in oil rubbed bronze finish and this model doesn't come in that finish. I want to switch out the fixture for one in oil rubbed bronze. Do any Moen fixtures interchange with each other? I don't want to have to cut into the wall and completely replumb the fixture. Also want to change the jetted tub fixture. Thank you.
Go to this link...
http://www.moen.com/buymoen/buyparts/index.cfm
Answer the pull down menu questions in the... "DON'T KNOW YOUR MODEL OR REPLACEMENT PART NUMBER?" section.
This will get you to all of the same model family to see available trim...
On models that turn to turn on and adjust you may substitute a lever for a knob to see additional possibilities.
If yours is the style that pulls out to turn on, your choices are limited. I don't think Moen makes dark bronze for that, and you will have to search online or the supply houses to see if an aftermarket company makes it.
