View Full Version : Tabs on plastic electrical box
toolguy504
07-09-2009, 10:40 AM
Is it OK if the tab on the box where the wire goes in breaks completely off or does it have to be on to act as a clamp. Thanks. Earl
Billy_Bob
07-09-2009, 10:38 PM
I suppose if you pointed that out to an electrical inspector, he might say you need to replace the box?
As a practical matter, I would think some caulking squirted in the opening should hold the wire in place. (or liquid nails, whatever)
What I would be concerned about is sometimes connections inside electrical boxes arc and send sparks flying. I would rather not have large openings through which sparks could fly out and cause a fire. (Keep any potential sparks in the box is the idea...)
toolguy504
07-10-2009, 04:06 AM
Thanks Billy Bob. Earl
Scuba_Dave
07-10-2009, 10:42 AM
The tabs on the single gang boxes break off a lot of times
Not required to caulk
You would not be required to replace the box
The 2 gang boxes the "tabs" are made to be like clamps
I've never had one of those break off
220/221
07-13-2009, 09:22 PM
The tab is only there to fill the unused hole, not to clamp the wire.
If it was a clamp, like on a cut in box, it won't break off.
It will however twist off with needle nose :D
