Thanks all for the great help provided here! I have gained much useful info from searching previous threads, but am still fuzzy on what to do with my tank.
I currently have a Well-Rite WR60 Online tank, about 15 years old, and am considering either installing a larger tank or a Cycle Stop Valve to extend the life of our pump. I had to replace the Jacuzzi Hurricane pump about 4 years ago, getting less than 8 years of service. The replacement is a Jacuzzi T5HR8P9.
I was thinking to add a CSV150 to the current tank setup (my pressure switch currently set to 40/60). Would I need to reset the cut-out to about 52psi, given the fixed 50psi of the CSV150? Are there problems with leaks with the plastic versions of these valves? Is it worth it go for the twice-as-expensive CSV1Z or CSV1W?
I also considered replacing the tank with larger, maybe a Well Mate WM12 or similar-sized, but I think my current tank T is a proprietary Well-Rite thread that would need to be replaced as well. Can I expect much more service out of my current 15 year-old Well-Rite? I am leaning towards adding the Cycle Stop Valve, and dealing with the tank when it fails.
Thanks all!
Thanks all!
