new_home_owner
06-29-2009, 06:19 PM
OK, Long story here made as short as possible....
New owner of a house built in 1949. This is a single story ranch on a slab with a decent attic.
I am remodling the bathroom and found the galvy hot water lines (coming up through the slab) into the bathroom have been replaced with copper lines coming through the attic. I don't know how they were disconnected or which way the original galvy lines are routed. They are not capped in the bath wall so obviously somewhere else there was a problem at one time.
So... as I remove water valves I discover that my cold water galvy lines are showing their age with rust build up and I decide, after much discussion, to run a new cold supply line (PEX) from the laundry room to the bathroom via the attic. In the laundry room there is a 3/4" supply line coming in and the washing maching, outside spicket and hot water tank run off of it. I figured I would "t" into this line to run my bathroom cold water line.
My problem is that today I discovered that my 3/4" supply line in the laundry room is actually 1/2" line which adapts into 3/4" about 2 inches from the slab, then back to 1/2 into the water heater.
So, other than spending thousands on a plumber I have 2 choices; I can stick with my plan and run the cold water line through my attic and into my bathroom (sink, toilet and bath/shower) after I tee from my laundry room OR I can just replumb the bathroom with fresh line and use the existing galvy that comes up from the slab.
Which should I do? Thanks in advance for any info.
I do wonder if my bath hot supply pipe originated from the laundry room??? I don't know these things.
Is splitting one 1/2" line into one cold and one hot 1/2" line going to reduce my volume too much?
edited to add: Home is on city water supply.
