View Full Version : Pressure Tank Flood Protection
weather777
06-26-2009, 12:58 PM
With a pressure tank in the main living area of the house ---is there some device that can be installed to shut off the pressure tank to prevent a flooded home in the event of a pipe leak/break?
Thank you
valveman
06-26-2009, 01:19 PM
A low pressure cut off switch works good if it is a line break. If it is a small leak, it won't help. You might try one of these.
http://www.statefarm.com/learning/loss_prevent/learning_loss_water_leak_det_system.asp
