Well Point Failure on Shallow Well??
Saratoga Jim
I bought a house with a 1 1/4" well point in the basement and I decided to hook up a shallow well pump to it to water the lawn. Sounds easy right?
Background, 1920s house, 1 1/4" pipe, 15 feet deep pipe below basement floor, 6 feet of standing water, entire area is 150 deep sand to the bedrock.
I can pour water into the well and it drains very slowly.
I bought a 1/2 HP shallow well from Sears and hooked it up. I got a little flow and a lot of noise (cavitation). Then I tried running a 1 inch pex pipe held 6 inches from bottom inside the 1 1/4 to draw up the water. I got a little flow. Tried 3/4 pex next and got the same.
Now I can pour water into the well and it drains quickly.
Next I tried a pitcher pump. After priming, I pumped up 10 gallons of water and then disaster. Sand was coming up. I was pumping up fine sand. Lots of it. I removed the pitcher pump and could only push pex halfway down the well. Blocked with sand.
What do I do at this point?? Flush the sand out with a garden hose? Did the point screen collapse? Do I need to pull and replace the whole thing?
If this is an existing well, it sounds like something rotted through and this is where your sand is coming in. As screens plug up over a number of years it's harder for water to come through, making sand even harder to come through. I think I would look at installing another well point with new pipe.
