water
It is like the disposer in the kitchen sink. When you are grinding, you use cold water to congeal the grease and make it a solid mass for the disposer to grind up. But if it gets into the pipe and congeals, then you need hot water to "dissolve" it and make it a liquid. After snaking the line, I fill the sink with hot water and run it through the disposer to flush the line.
