turtle
07-27-2005, 05:44 AM
Hello,
Problem we have a finished porcelian floor installed around the existing flange.
There is a 1/2 inch floor difference. The diameter of the hole is about 8 inches. Do they make a kit that if the flange is raised, or replaced? that will span that 8 inch gap and sit on the tile? Also how do you drill through the porcelian tile?, and if you do, when you install [screw in the flange] would you get the push back by the screw?, would this seperate the installed layers of subfloor [2], backerboard, and tile? we are going to have a plumber do this, but the last plumber just put in flanget extenders on the existing flange.
Thanks,
turtle
Thanks,
turtle
