10" Rough-in with Dual Flush?
philk
Do there exist toilets with ten-inch rough-in and dual flush?
The space requires a compact toilet with a 10" rough-in. I would like to have a reliably flushing, water-efficient toilet with the dual flush feature. I have yet to find anything with that combination of features.
Phil K.
Caroma makes a dual flush that has a swivel adapter that let's you install between 10" and 12"
The 270 bowl uses an offset adapter so you can adjust the rough-in from 12" to 10"
Underneath the Caroma 270 bowl.
Follow-up questions
Thank you for the possible answer.
I had eliminated Caroma from my search because the claim that "one size fits all" usually means it fits none.
Since there are no other candidates, I guess I will reconsider. I can imagine that a "swivel adaptor" might enable connection to a waste pipe over a range of rough-in distances. But what about the holes for the bolts that hold the bowl part to the floor? I find myself suspecting I will have to make new bolt holes at possibly very inconvenient locations.
Also, what is the exact criterion for measuring the "length" ("overall length"?) of a toilet? The front of the bowl of the current toilet is 27 5/8 inches from the wall. The opposing cabinet door barely clears this now. The Caroma claims a length of 28 3/8 inches. Are we talking about furthest distance from any part to the back wall? If so, then measured under what "rough-in" distance?
