Gasline elbow on 1936 Norge
joching
I'm looking for a gasline elbow that is a flare fitting on one end and threaded (27/in) on the other. The gas nipple (or diffuser - different ones for natural gas or propane) screws on to the threaded end, and the flare end leads to a copper line that goes back to the burner valve/control. The elbow is brass. Where would I find what looks to me to be a pretty standard piece of gas hardware? Thanks, Joe
elbow
We have absolutely no idea which piece you are looking for, but if it is part of the burner assembly then it is not a "common" gas line fitting. And there are few fittings which are specific to gas lines.
take it to a hardware store, they may be able to recognize it, or post a picture
Sounds like you need 1/4 flare by male 90...
Are you talking about pilot tubing? But it almost sounds like this is tubing leading to an orifice because you said you change them over for propane and natural gas. Regardless... remove the the part and take it to a good hardware store or a plumbing whole-saler. You should beable find something to directly replace it. If not they'll show you what you can use instead.
