View Full Version : What is smallest pvc bend?
canton
07-24-2005, 05:31 PM
I need a 1/32 bend, is it available?
jimbo
07-24-2005, 07:03 PM
A 1/16 th bend ( 22½º) is the smallest I see in the catalogs.
Why do you need such a small angle, and what are you tyring to connect?
canton
07-25-2005, 08:31 AM
I came off a 4" waste line which was laying @ a angle going out side. I came off the 4" with a 4 x 3 Y then to a 45 but it isn't quite straight due to the 4" slant, I tried the 1/16 bend but its a little off as well. This is all for a basement bathroom, I might be able to make up the difference on the 3" run to the toilet. However I do think if there was a 1/32 bend it would be perfect.
plumguy
07-25-2005, 03:17 PM
I've never installed 4x3 wye that needed that type of bend! Between rolling the wye and 45's you should be able to get you're angle and maybe installing an ocassional 22 1/2
plumber1
08-09-2005, 08:34 PM
Right on plumbguy
