View Full Version : need help with dvw routing
prols1
06-08-2009, 09:19 PM
hi all, newbie here looking for some help. im looking for suggestions on how to to connect this 1st floor bath plumbing together and get it over to the main waste line... properly of course, thats why im here. the wc drain will be 3" pvc and it is 5'6" from the lav drain/vent; and 6' from the main vent. excuse my terminology, i confuse the soil stack & waste stack terms on a daily basis. this bathroom is above a full basement with a 8' ceiling and the drain leaving the house, on the left wall, is appox 4' high. i would like to keep it up high as close to the joists as possible, without drilling through or notching, then drop it down via 90, 1/8 bend, and wye to the main line out. if i left out any info that you might need, just ask, and ill answer as best as i can. thank you!!!
ps *dwv routing... sorry. lol
06-09-2009, 08:45 AM
It is almost, if not completely, impossible to lay out your DWV system without actually being there because there are too many variables which we cannot see, and you could not describe properly.
nhmaster
06-10-2009, 04:31 AM
If that 3" vent through roof is already attached, leave it alone. If it's not, and it has nothing run into it get rid of it, you don't need it. Everything else in the bath group will wet vent through the lav.
FloridaOrange
06-10-2009, 05:55 AM
Wouldn't that only work if you knew the layout of the second floor to create a vertical wet vent or stack vent between the floors? If that 3" coming down is just the main coming down wouldn't that effectively remove the venting for the shower and water closet?
I'm not saying it's wrong, just saying that I don't see how it's right.
06-10-2009, 07:18 AM
That drawing would work, (although few inspectors would approve it), UNTIL you added the upstairs bathroom and as soon as you did that the only thing vented would be the lavatory, and you would have created major problems for the TOILET AND TUB drainage.
nhmaster
06-10-2009, 11:53 AM
Oh hell, I didn't read very well. No that 3" from the upstairs can't tie in there it would have to be downstream of the first floor group.
prols1
06-10-2009, 03:21 PM
hey guys, thanks for the replies so far. the drain from the 2nd floor bath is only a drain, it does not continue up through the roof. the vents for the fixtures up there (toilet & sink 2", tub 1 1/2") are tied back into the main 3" vent that runs down into the closet wall. im in westchester county, ny; in a fairly strict district, so i wanna do it right the first time. ive read alot of your replies from other posts, so i know you guys can come up with a correct solution for this one. i have faith. :)
prols1
06-10-2009, 03:36 PM
the 2nd floor bathroom is already there. this is a first floor bath remodel. all thats left for the rough in is the connections in the basement.
FloridaOrange
06-10-2009, 05:07 PM
If I were to us NH's sketch, all you would have to do is branch off the main be ore the wall for the toilet use a 2" vent in the wall. Before the vent branch off with a 2" to the shower a long as that run was less than 8'.
prols1
06-10-2009, 07:05 PM
that wall contains a/c ducts going up to the 2nd floor and across the top, so i really cant run any vents up that wall.
im thinking that if i run the lav drain over to the main vent stack, itll create a wet vent then allowing me to run that vent horizontally to the toilet. will this work? and if so... where should i tie in the shower drain line? please, anyone feel free to suggest a better way.
FloridaOrange
06-11-2009, 05:50 AM
That's pretty close, if you have room (elevation) to go over the top of the main I would do something like this then.
The biggest problem I've seen with remodeling almost any plumbing system is elevation of the existing and you're connection point, almost everything else can be overcome.
nhmaster
06-11-2009, 11:39 AM
Nope, the 3" drain from upstairs needs to tie in downstream of the first floor bath group for the wet vent to be legal.
prols1
06-11-2009, 01:26 PM
am i gettin closer???
06-11-2009, 08:08 PM
not there yet. The toilet CANNOT connect ahead of the shower, unless the shower has its own vent. But the shower vent CAN vent the toilet if done properly.
FloridaOrange
06-12-2009, 06:56 AM
If the lav line is going over the top of the 3" from upstairs, I don't see what's wrong with what I posted. The wet vent is separate from the line from upstairs.
prols1
06-12-2009, 08:22 AM
i can only guess, but im thinkin the toilet and shower need a 2" vent, and that the 3" main isnt hooked up.
prols1
06-12-2009, 08:23 AM
im not giving up yet! however, if i dont figure this out soon, i might have to convert both bathrooms into closets and put a porta potti in my driveway.
am i correct in thinking the lav vent is not big enough to vent the shower and toilet, since its only 1 1/2"? and that the 3" main vent has to be "wet" before i can run it horizontally?
heres another try....
FloridaOrange
06-12-2009, 02:13 PM
If the Vent at the lav is 2",that makes the horizontal waste line the vent. That line provides the vent for the shower and toilet.
prols1
06-12-2009, 06:01 PM
ok, that i understand, but my lav drain and vent is only 1 1/2". also, i believe i need a continuous 3" vent to the roof. that 3" drain from the 2nd floor doesnt run up through the roof.
FloridaOrange
06-12-2009, 09:12 PM
I would run the lav and vent as 2", you should have vents thru roof from your upstairs plumbing. Vent through roof size will be per your local code. Florida VTR can be 2", 3" isn't required anymore here.
prols1
06-12-2009, 09:23 PM
i see now it wouldve been easier if i did run the lav in 2", but its too late for that now unless its impossible to connect all as is now. the 2nd floor fixtures are vented with 1 1/2" & 2" vents that connect back up into my main 3" vent, then that continues up through the roof now.
do you see any problems with my last idea?
Pipedoc
06-13-2009, 02:15 PM
It seems to me like this might be easier to explain with an isometric drawing. Here is what I come up with. I don't know the codes in your area but this is fine for Illinois. Drains in black and vents in blue.
I apologize for my computer drawing skills.
Without seeing the jobsite or detailed pictures it is impossible to tell you exactly how to run the dwv. The isometric drawing will cover one of many possible ways to pipe this. You will have to adapt to your jobsite obstacles/specifications/local codes, etc. It appears from your drawing that you may not be able to run the vent bar as per this drawing, so possible options would include a soffit in the ceiling or taking the vents up to the ceiling seperately, etc. You get the idea.
Hope this helps.
http://i691.photobucket.com/albums/vv273/Barrister_Baiter/Iso.jpg
