View Full Version : Pressure drop due to temperature change?
Noth Jersey
06-06-2009, 08:37 PM
What is the magnitude of the pressure drop in a gas line that can be attributed to temperature change? I pressurized the line with air for a leak test. The pressure dropped from 17.5 psi to 17 psi over about three hours. I noticed the temperature of the attic, where about 2/3 of the line runs, dropped around 15 degrees during this time. If you're doing a 24 hour test, what kind of pressure change could be chalked up to temperature?
jimbo
06-06-2009, 10:07 PM
This pretty well sums it up:
http://en.wikipedia.org/wiki/Ideal_gas_law
The pertinent equation in this case is for contstant volume:
P2= P1(T2/T1)
kingsotall
06-06-2009, 11:27 PM
And in laymens terms...¿
jimbo
06-07-2009, 05:29 AM
P1 is your starting pressure. Multiply it by the ratio of the new temperature divivided by the original temp. to get the new pressure P2..
I have to double check what units the temp. must be stated in. It might need to be kelvin.
edit: yes, temp. is in ºK. So, lets take an example:
starting Temp. 80º Ending temp 65º
starting press. 15
ending pressure = 15 X ( 291.98/299.81)
ending pressure appro. 14.6 PSI
note: I hope PSIG is the proper unit for pressure. Might it have to be PSIA?? I have to sort that one out!
One the temperature stabilizes, the pressure should also. That is why the inspector usually only checks it during a 15 minute period, assuming you have a very delicate gauge.
Winslow
06-07-2009, 04:17 PM
I use a manometer to test gas lines. It is by far the best method. I use a mercury manometer to test rough piping (as per UPC) and water manometer to test final. It let's you know instantly if you have any leaks.
Noth Jersey
06-08-2009, 08:13 AM
I kept the line under pressure over weekend. After it bottomed out, it rose half a PSI by Monday morning, so I feel pretty confident I'll pass my inspection.
I should have thought of using the manometer I bought for my HVAC projects. I was just using a 25 psi gauge with .5 psi increments, which is what the propane company and the inspector will look at.
Here, it has to be a 10 psi test using a 15 pound gauge with 1/10 psi graduations. Even a manometer will respond to the pressure variation from temperature changes.
