Questions about the Plan
My main questions about this plan are:
1. Will the vent line work and be in code if it goes vertically up 7ft immediately from the pump then travels 15ft laterally before going vertically again and exiting through the roof?
2. If this is not ok what would work or be in code - how far laterally is the limit of travel for a vent line?
3. Will all three fixtures have the appropriate venting in the design below (with the current vent set up or with an immediate vertical vent)?
4. If the design below does not have the correct venting, what is wrong and how could it be set up correctly?
Thanks for any help the forum can provide. I'm a novice at plumbing and find the design, planning, and execution interesting and enjoyable to learn and do. Based on various posts I've read I believe there are a lot of knowledgeable, experienced, and professional people in the forum and appreciate any feedback that is provided.
