View Full Version : Cap for Sewer Cleanout Standpipe
leepj
06-06-2009, 10:40 AM
I just replaced the standpipe in the front yard, and now it needs to be capped off. It is the "standard" 4" pipe, plastic. I've seen the type that is glued into the pipe, with a screw-in cap. The cap has a square knob on the top for a wrench. Is this the proper type to use, or should it be a metal cap?
SewerRatz
06-06-2009, 12:46 PM
Plastic plugs are just fine.
Use a plug with slotted recesses on top rather than the square lug. Your lawnmower will like it a lot better.
Ian Gills
06-07-2009, 01:32 PM
Looks like a trip hazard to me. ;)
psolutions
06-08-2009, 03:30 AM
As suggested above the cap would be best recessed to for obvious reasons.
However, also consider that many counties are now requiring brass caps.
The reason is so they can be located if they become buried or non-visible. If its not new construction you can get away with plastic, but if its low to the ground or may become buried you might want to consider brass cap for easy locating in future.
leepj
06-08-2009, 08:13 AM
I like the look of the solution in the picture. It should be perfect for me, as the cleanout comes up in my front garden, therefore no lawn mower complications! Also I can easily control the height, so burying will not happen. I am reluctant to do anything that is metal, because it eventually corrodes and cannot be opened. I have a brass cleanout inside the house in the basement floor that was buried in the cement floor for 34 years until I finally found it. Now it cannot be opened. If that happened inside, I can just imagine what an outside cap would do.
Thanks again for this. I will buy the parts today!
SewerRatz
06-08-2009, 08:47 AM
use a good Teflon pipe dope on the threads, even if you use plastic. Brass plugs can be easily removed with a hammer and a chisel. When I replace them I put plenty of Teflon pipe dope on the threads of the new plug to ease removal in the future.
SewerRatz
06-08-2009, 08:52 AM
For those that have clean outs in the lawn here is a picture of a slotted plug that HJ referenced to in his post.
