P PeteB New Member Messages 3 Reaction score 0 Points 0 Jun 3, 2009 #1 If ABS pipe and fittings are used for draining hot water from a dishwasher is solid core or foam core more desirable? What is the difference between the two? Thanks for any advice.
Master Plumber Mark Sensitivity trainer and plumber of mens souls Messages 5,927 Reaction score 535 Points 113 Location indianapolis indiana - land of the free, home of Website www.weilhammerplumbing.com Jun 3, 2009 #2 always do the solid.... the price difference is nominal... probably less than 10 cents per foot.... so why not just use the heavy duty stuff
P PeteB New Member Messages 3 Reaction score 0 Points 0 Jun 3, 2009 #3 This is the first time I have used ABS. I assume the heavy duty stuff is solid. Does solid have a higher temp. rating?
hj Master Plumber Messages 33,613 Reaction score 1,057 Points 113 Location Cave Creek, Arizona Website www.terrylove.com Jun 4, 2009 #4 Abs Usually you have to use whatever the supply houses stock, but we use it for all drainage purposes.
NHmaster Master Plumber Messages 3,176 Reaction score 5 Points 0 Location S. Maine Jun 4, 2009 #5 I have seen foam core used on commercial dishwashers that looked like spaghetti after the 180 degree water hit it.
