DWV Joining to Terracotta Pipe
mel_b
Could some one please help me as to joining DWV Toilet pipe to terracotta watse pipe. :confused:
Thanks
joint
You have to have a "plain end" piece of pipe, not a bell and then use a Mission, or other brand" coupling with one side sized for "clay" pipe and the other bor the DWV, although you might have to use a bushing in the DWV side if your supplier does not have the proper sized reducing coupling.
mel
we need the pipe material type you are joining to terracotta !
dwv is the plumbing application, not material type
chances are it,s either cast iron,pvc, or abs
