rmateyko
- Messages
- 4
- Reaction score
- 0
- Points
- 0
I am working on a bathroom where the sewer line configuration worked out so that the street part of the closet bend that is connected to the sewer line, sits about 2.25 inches above the surface of the current concrete floor. I plan on adding height to the floor for an in floor heating system and tiling but the 2.25 inches is still high. The closet bend is 4 inch ABS and I plan on installing a 4 inch plastic closet flange on the street part . The closet bend collar is 1.75 inches deep. I have included pictures.
Can I cut some plastic off the closet flange collar and off the street to reduce the final height of the sitting closet flange. Let's say .75 inches off the closet flange leaving a collar of 1 inch depth? That would give me a final height of 1.5 inches. I can't chip into the concrete floor because the closet bend curves just under the surface - what is exposed is the whole street.
A secondary question is what is the opinion on instead of using a 4 inch closet flange I use a 4 to 3 inch flange and fit it into the 4 inch street.
thanks ahead of time.
