medeamedea
- Messages
- 1
- Reaction score
- 0
- Points
- 0
My original tub/shower situation was this: cast iron tub with vinyl shower surround. Two of the three walls are stud walls, the third (where the fixtures were placed) was a 3/4" plywood sheet which formed the side of a built-in cabinet. There is about 16" between the tub and the wall.
The shower valve and tub/shower spout pipes were pretty much pushed through the plywood.
I have removed the built-in cabinet (wood was rotted from leaking) and would like to replace it with a freestanding one, 15". However, the plumbing guy at the store pointed out to me that the shower valve should be secured to a block nailed to studs. Which I don't have, just a cabinet which is 21" deep. I was going to screw a 2x4 to the back wall to have a base to install new tile backer board. So the board would be attached to the cabinet and one stud to form the fixture wall.
My question is:
Can I install some supporting lumber inside the cabinet to attach the block for my shower valve? Is there anyway to make this work and have the valve properly supported without building a new stud wall? I don't mind doing it but the bathroom is so small I would really like to use that space for storage and a pre-made cabinet is going to be more practical.
Thanks!!
My question is:
Thanks!!
