Molo
I was talking with an HVAC guy and he said that you should not do a soap test with 15psi on a gas line. He said the pressure should be reduced otherwise the bubbles will pop and not be seen at high pressure. Would you folks agree?
Not if you use the right bubble mixture, AND do not have a massive leak.
I use kid's bubble solution. It sticks to the joints better and will show even a small leak in a few minutes.
I use kid's bubble solution. It sticks to the joints better and will show even a small leak in a few minutes. A gas sensor is useless if you are testing with air, which is the case when you have 10 psi in the system, as per code. New systems, and those with the meter locked because of a leak, will show nothing when using an electronic gas detector.
I like Dawn dishwashing liquid slightly diluted.
