oceannative
- Messages
- 4
- Reaction score
- 0
- Points
- 0
Hi all, thank you in advance for any assistance... I have a H2ow-to pump that indicates it was installed pre-pressurized. I don't know how old the pump is, but I do know that it's at least 5 years old. We have rust issues with our water (toilet valves and washing machine filters get rust buildup).
We've never had great pressure while we've lived here, but lately, it seems that we have great pressure when the water turns on (more so than usual), then after 30 or 60 seconds, the pressure and flow just decrease to almost nothing.
After reading through a few posts, I went outside and checked the standing pressure (pump wasn't on) and it was 70psi. I decided to see what the pump would do when the water was turned on, and when I went back out, the standing pressure was at 80psi. When the water was turned on, the pressure dropped to 60psi before the pump turned on. The water pressure and flow was ok for about a minute before it was almost nothing. The pump kept dropping to 50psi, then stayed there for a couple of minutes until we turned the water off... then the pump stayed on until it hit 90psi
(isn't that too high??!!).
Any ideas? Also, should I be concerned about the high pressure?
