Kind of hard to tell, but it doesn't look like you have enough depth to get the trap installed properly unless the shower pan is really thick creating a big step up. Is the liner pvc or lead?
The liner is PVC. and it wasn't in very good condition. I don't *think* it was leaking from there. How long should a liner last?
The shower pan will be somewhat thick, as the whole bathroom floor is bumped up. You walk in, then step up three inches. So in the pictures, I've removed the previously-built shower pan and gone down to the true basement floor.
You may need to crack some concrete and check the state of the pipes. If I was going to go to the trouble of installing a new shower, I'd want to probably check and replace the maybe ancient cast iron. It could be in great condition, but it could be totoally rotten.
I did some of this last night. Incredibly hard to do by hand! Is there a small automatic tool (electric or pneumatic) that I could use? I'd rather not hire someone if possible, and I'm not ready to deal with a large jackhammer yet. My husband may be up for it, though... The paying work gets in the way of these projects, doesn't it?
What I did discover is the pipe is steel - looks like galvanized. And, there is a rusty area on one side. I can't see the extent of the rust yet since I chiseled for a couple of hours and only uncovered the top 1/4 of the pipe. What I'm afraid is that it runs under the raised (concrete) floor over to the toilet, and that the leaks are over there, too. We recently had a french drain installed on the interior perimeter of our basement to stop seeping and they covered it back up with concrete for us to finish off. (That's how this project started - repairing tile in the bathroom where they jackhammered. Then it turned into re-tiling the whole bathroom, and now we've evolved into replacing the shower stall). I patched the concrete to make it level so I could re-tile it, and it took longer for the cement patch to cure in the area near the base of the toilet. It stayed damp for days after the rest of it had cured. We just ignored that (ha ha ) but now we're afraid it's related to this steel pipe.
This is all coming together now: we've had a slow leak before at the base of the toilet and replaced the wax ring - twice. The leak has disappeared, at least from the floor vantage point. Now I'm wondering what's going on beneath the tile and beneath this raised concrete floor that was added to the true basement floor when this bathroom was added. Oh the joys of owning a 100-yr-old house, especially when previous owners have had their turn at home-improvement projects.
Can't really see the drain. This should be a clamping drain, and it could have been leaking there from the liner.
This drain is a clamping drain, and the concrete around it came off extremely easy. Was a little "gooey"... Could there have been an additive in it?
And thanks so much for the responses... I really didn't think it was the pipe that was the problem but you were right - rusted almost completely through. That's why we're posting here...
