Still asking for advise
OK folks, while my submersible is getting worse, my computer has just been repaired.
While I was off line you went on a sand tangent.
The well is 110' deep with 6" steel casing of undetermined length. The pump is suspended at the 60' level, while the water is 40" below grade level, thus we have 20' of water above the pump and sand 50' below the pump.
The casing is most likely dropping rust particles over the the top of the pump.
The material I have removed from 2 prior pumps is magnetic and appears to be rust nodules rather than sand.
I lowered the operating pressure last may from the normal 40-60 psi to 40-50 psi , but today the pump lost the ability to hold flow at anything more than 48 psi.
Are auxiliary screens available that will clear the pitless adapter, and not impede flow to the pump intake screen?
