View Full Version : Fire Hazard? Expanding Foam - Electric Boxes
molo
05-08-2009, 06:47 PM
Is there a fire hazard created when you put expanding foam around electric boxes? What, if anything, is safe when using the foam around a box?
Thanks for any replies:)
Speedy Petey
05-09-2009, 04:46 AM
Supposedly foam is fine around boxes. Just make sure all holes are sealed so the foam does not enter the boxes.
Thatguy
05-09-2009, 03:01 PM
In that case heat dissipation from the box due to IČR loss and bad wirenutting/connections depends on heat conduction through the copper and the cover plate being at room temp. I guess the NEC has already figured the boxes would be insulated with no air flow around them.
Speedy Petey
05-09-2009, 03:21 PM
I have never heard of "heat dissipation" around electrical enclosures being an issue.
A failed connection just need to be contained for safety.
I would say the NEC definitely has considered this assuming many boxes and enclosures are on exterior walls and ceilings.
Thatguy
05-09-2009, 03:28 PM
I guess that means that enclosures have, or the air in them has, never gotten to 120 °C :D
"Wood slowly chars [at] 120°-150°"
but failed connections certainly have
"Electrical arcing [up to] to 3750°[C]
I guess air is pretty good thermal insulator.
