View Full Version : Mending Copper Oversized Tee?
Dkrasko
05-04-2009, 07:36 AM
I'm removing and replacing a 3/4 copper Tee. Is there a supplier that makes a wider tee to make up for the 1/2 inch+ of copper tube I'll be cutting off?
Redwood
05-04-2009, 07:40 AM
No, you could cut off more and use a piece of tubing and a coupling to make up the difference. Other options are a possibility but not being there to see it I cannot say what they would be.
Dkrasko
05-07-2009, 07:10 AM
I'm off to add the splice! Thanks
Gary Swart
05-07-2009, 10:01 AM
Just one of the positive advantages of copper over galvanized! You can cut and paste to make things fit without cutting and threading and adding expensive unions. May look a bit like a hack job, but if the sweating is done right, it will work just fine.
