View Full Version : Broken-off pipe in shower spout
glair
07-15-2005, 10:17 AM
Anyone know how to get the broken-off male threaded 1/2 inch pipe out of the female threaded end? Male end was corroded and 1/2 inch stuck inside the pipe.
RioHyde
07-15-2005, 05:37 PM
You can buy nipper extractors of varying sizes at a plumbing supply house and possibly from the guys in the orange aprons.
jadnashua
07-15-2005, 05:39 PM
You could use an EasyOut if you can find one large enough. They make an inside pipe wrench, but I think they only work on larger pipe. An EasyOut is basically a lefthanded threaded tapered hardened steel hunk. You put it inside the hole, and then use a wrench to back it out of the wall like a screw.
http://www.terrylove.com/images/pipe_extractor.jpg
glair
07-15-2005, 08:50 PM
Thanks for the suggestions!
plumguy
07-16-2005, 07:20 AM
You can also try a hack saw blade and carefully cut thru the nipple and pry it out with a thin flat screwdriver. Just be careful not to cut thru the female threads.
