View Full Version : Bending type M rigid copper
Mr. Overkill
07-15-2005, 08:06 AM
Hi all, I hope you can help.
CX from John Bridge forum sent me over here.
I have 2 threads going over there:
http://johnbridge.com/vbulletin/showthread.php?p=279339#post279339
http://johnbridge.com/vbulletin/showthread.php?t=24312
I've been construction phase of building a house for over a year now doing alot of the work myself.
I'm back on the shower project after taking a sabbatical to accomplish a few other projects around the house like changing toilet drain locations and squaring up doors and windows from drying lumber and cement settling.
I am now tackling the rough-in plumbing for the steam shower and ran into a few problems with the routing of the copper lines and stud warping.
1st the stud problem:
I have already replaced 3 studs that were the worst off (warping inwards or outwards of the shower) and blocked another 2 that were warping side to side. The 3 studs I replaced are already warping after only being in for 3 weeks. I am now officially sick of fixing and replacing studs. The only studs I could get around my area are either already warped or are so heavy with moisture, they warp very quickly in the Pahrump climate (today it was 110 degrees with only 4% humidity) I could almost watch the wood drying out and twisting in front of me .
Framing questions:
1) How much of an outward warp will I be able to compensate for during the tiling stage (I know that a board warping inward can be planed)?
2) Seeing on how getting straight lumber around here is next to impossible, if a board is to warped for compensation, should I go with the cut and shim solution for straightening?
3) Can a layer of mud be applied to the Durock to get my even straight walls?
4a) Or should I just forget the Durock plan and attempt a mud shower to get my straight walls?
4b) If I go with the mud shower how much thicker is a mud wall compared to ½” Durock? (to adjust my valves appropriately)
2nd the pipe routing problem:
My shower will have 2 shower heads, 4 body sprays, 1 rain from ceiling, a hand shower, a steam head, and 2 valves with selectors all on 2 walls. I am using ½” rigid copper pipe for the water lines and routing is becoming a problem since there is so much going on inside the walls. Some of the pipes being on the same plane are in the way routing another.
Pluming question:
1) To get away from using to many 45’s is there a trick to bending rigid copper just enough to get around another pipe without kinking it?
(I’m not particularly fond of using the thinwall pipe, I want my shower to last as long as I’m in the house)
Thanks in advance for advice -
I'm in a rush to finish the rough-in to get my inspection and move on the next stage, I am already 2 ½ months over schedule and my better half is turning into something other than better.
-David
master plumber mark
07-15-2005, 03:04 PM
Why cant you just use a roll of soft copper type L???
Now ....to bend hard copper
in the mid west bending the pipe to make a
45 degree has been called makeing a "german elbow"
I have actually seen it done with 1/2 or 3/4 in GALVANIZED pipe
by old timers that needed to cheat just a smidgen.....
I remember my grandfather takeing a piece of 3/4 galv pipe and
heating it up to bright red, then beating it against a telephone pole!! LOL
I suppose the galvanized pipe is still working ok
(43+ years have passed)
So its not a big deal to bend the copper,
try it first to see what I am talking about
first you evenely heat the pipe along where you want to make the bend
to cherry red probably along about a 6 inch area....
this basically softens the pipe,
then you let it cool down slowly then just hand bend it to a 45
but be careful not to kink it.... its best to wear gloves.
I have done it for years when I needd to cheat
a little with never any problems at all.
its no big deal
Now the shower you are installing sounds like something
out of my worse nightmare.....
if everythignd is warping this badly have you considered
just installing some acrylic imitation marble walls
or somethiing that might be more forgiveing???
that is a mess that is going to come back and bite you
in the ass if their is a possiblinty of warping after you are done...
good luck
Mr. Overkill
07-15-2005, 04:53 PM
Thanks for the reply Mark I really appreciate it.
I wanted to use the type M pipe for the added protection of the thick wall copper.
I already tried using a conduit bender and that kinked it within a 10 degree bend, I like the heating idea. :D
I will try heating and bending tommarow and let you know how it went.
I don't know if the warping studs are considered that bad but it is warping anywhere from 1/8" to 1/4" at center of stud which will be noticable after tile is set. And yes warping after the job is done dose scare me.
I haven't seen the acrylic imitation marble your talking about do you have a link to that.
My shower is 4'6" x 6' with a 8'4" ceiling sloped down to 7'2"
Thanks again for your help. :)
-David
RioHyde
07-15-2005, 05:35 PM
Type L has a thicker wall than type M copper. I've done the same thing that Mark described in bending rigid copper. Works just fine though it might be easier for you to use type L soft copper for the installation.
captwally
07-16-2005, 05:21 AM
What are you installing, a shower or a Human Car Wash? I'm joking of course, but bending ridgid copper scares me. I'd either use flexible copper from the POC to all the outlets in your shower, or high pressure flexible poly pipe with compression fittings. Contrary to anything you may hear, there is nothing wrong with using compression fittings, no matter WHERE they are, as long as they are properly installed. Check out the thread discussion here under "General."
You'll read everyone's pros and cons. That's why this is a great place.
plumguy
07-16-2005, 05:37 AM
I have never bent pipe, but have used plenty of soft roll that I thought was type K.
07-16-2005, 07:57 AM
Back to the bending of galvanized pipe. EVERY hand vise has a mandrel on the top that is used for bending up to 1" pipe. Bending type "M" copper is a bad idea even if it is heated. The walls are too thin so you induce stresses into the material, even if you do make the bend without kinking.
jimbo
1. With regard to the comments about compression fittings: we have had great discussions here about how wonderful and reliable they are for stop valves and supply tubes. The fact remains that codes usually do not allow use in a non-exposed area.
2.. Most places, you CAN buy kiln-dried studs. The green ones may continue to warp over time in your situation, which would be bad for the tile job. Even HD sells dry studs, so I sugest you bop over to Henderson and get those. Then you should be able to install a plumb and flush plane for the backer.
Mr. Overkill
07-16-2005, 06:09 PM
I appreciate all the replies. :D
Well I spent the whole day working on the house today on other projects after trying the heating and bending idea. It worked really well but ended up not using it anyway. After it cooled down I was still able to bend the pipe almost as easily as when it was hot. The pipe seemed to soft for me to be confident using it in my wall. I guess I'll use the type L copper and call it a day.
Besides after looking inside the test peice of pipe there was flaky stuff on the interior wall that did not look kosher to me, so I cut it open to get a better look.
I took a couple of pics for all to see. Maybe someone else can learn from my experience.
The 1st pic is the fished pipe that looked good but to soft for my taste.
The 2nd pic is a look inside at the flaky stuff.
The 3rd pic is a look inside after I wiped the flaky stuff off with my finger.
-David
RioHyde
07-16-2005, 07:55 PM
The flakes you see are caused due to the fact that oxygen was in the line while it was being heated to the point of being cherry red. Just something I hadnt thought to mention. If the line had been purged with nitrogen then heated the flaking wouldnt have happened.
I do believe you'll be in better shape either using the soft copper or soldering in two 45s to make the offset. If you do go the soft copper route just take care not to kink it and you'll be fine.
Good luck!
Mr. Overkill
07-16-2005, 07:56 PM
I have a little extra time on my hands while my wife is cooking dinner so thought I'd give a more personal reply to all.
Mark-
Liked your idea but don't think its for me, thank you anyway. :)
RioHyde-
I was under the impression that Type L was thinner than Type M because of the rigidity (if thats how you spell that). I guess I was wrong again. :o
That is the whole reason I wanted to use Type M and cheat the bend. But if Type L is thicker, I feel more safe using it. Thanks
captwally-
My wife says the same thing about the car wash. I like alot of hot water, and the spa shower will up the resale value of the home -its the new in thing-. As far as compression fitting are concerned, I have no problem with them, my whole house is plumbed with PEX an manna block. I just didn't want to put to many in the shower itself because the compression fittings actually restrict the flow alittle and with so many shower heads I'll be pushing the envelope on water pressure as it is. Thats another reason I didn't want to use extra 45's and bend the pipe instead. And yes, I like this site as much as John Bridges site. Thanks
Plumbguy-
I have never heard of Type K copper. I thought the type on a roll was Type L.
If anyone can clarify it would be appreciated.
hj-
As my previous post stated after the pipe cooled down it was still soft. So your rite on that one. Thanks
jimbo-
I would go to HD but for me its about 75 miles to the closest one up and over the mountain. (Henderson is actually farther for me) I have a CV joint on my car that has be making noise when I accelerate around a corner and don't have the time or money to tackle that until I move in the new house. Not worth puting extra miles on the car that I can get away from. I will just shim before I put up the Durock. Thanks
-David
Mr. Overkill
07-16-2005, 07:58 PM
Thanks RioHyde-
Is the soldering process on the soft stuff the same as the rigid?
-David
Dunbar Plumbing
07-16-2005, 09:49 PM
Yes. It is the same as hard copper.
jimbo
07-16-2005, 10:23 PM
The 3 common types of copper THICKNESS are K, (thickest wall), L (medium) and M ( thinnest).
Copper TUBING is commonly available as type HARD ( usually referred to as copper pipe, the rigid 10 foot sticks) and type SOFT ( the rolls)
When you heat the tubing to bend it, you anneal the hard back to soft. The other characteristics are not changed.
Mr. Overkill
07-17-2005, 09:44 AM
Thanks RUGGED and jimbo,
I'll go buy some soft copper today and start soldering.
-David
07-17-2005, 11:10 AM
After heating and bending the tubing you would have had to reheat and oil quench it to restore its temper. "K" and "L" both come in rigid and soft tempers. "M" only comes in hard temper. To avoid the internal oxidation you have to have the tubing filled with an inert gas, nitrogen being the most common one used.
master plumber mark
07-17-2005, 03:04 PM
What are you guys planning on putting through
these pipes anyway, nerve gas???
I have made "german elbows" on type m copper pipe for years
and years used in lots of situations under full pressure
with absolutley no problems.. never a single one
I suppose maybe I made a mistake about how hot to
get the pipe, after you have gone up and down the pipe with
your tourch, when it just starts to turn red, STOP
you are not supposed to melt a hole through it.
all you are doing is softening the copper , if you feel more
comfortable , use type L , it is thicker and will bend just
about the same way....
Mr. Overkill
07-17-2005, 11:50 PM
Well the town is out of soft copper so I started soldering the other pieces today. It started off bad when the solder wouldn't seep into the joint. I figurred it was a flux problem since its been in the hot van for about 2 weeks so went to get some fresh stuff. That did the trick. By the time I dismantled my valves and got everything sanded fluxed and straight and level on the cement I didn't get much soldering done today. I only soldered 22 joints today. The sanding and deburing took longer than expected and my fingers are killing me from the inside sanding, I guess I should have invested in wire brushes instead.
hj-
1) Does tempering make the pipe (or I guess tube is the proper name) less likely to pit and spring a leak over time?
2) Which type of tubing is considered the most reliable (soft, hard, K, L, or M)
I've never seen or heard of K.
mark-
when I heated the copper it was next to impossible to distinguish when it actually turned red since the copper is almost a red anyway. Is there a trick to now when it is actually red with the naked eye.
David-
Mr. Overkill
07-18-2005, 07:10 AM
This is the 1st time I ever actually soldered in vavles and didn't realize how long it took to heat up the valve before the solder would melt, even though I was using map gas. After soldering all the valve connections I was sort of in the heating mode and might have over heated a few tube to elbow fittings. Also since I was sweating my connections on the concrete one of my "T" fittings got out of position and it turned up alittle, So I reheated it and twisted it strait.
1) Will heating a sweat connection more than is neaded create a bad solder joint.
2) Was reheating a sweat connection and twisting it a no-no? should I have taken the whole assembly apart and start over?
Those 2 thing have been bothering me all night, I don't want any leaks when I do the water test. Its always harder to resolder after everything is wet. Although just to redo that 1 "T" I would have to redo atleast 2 other fitting also. What do you think?
Thanks in advance for your advice.
-David
Mr. Overkill
07-19-2005, 06:15 AM
I could not find a drop L in the T configuration to make my body spay pressure loop so I T'd off to regular drop L's.
Is this configuration OK, or am I crating more pressure loss with to many corner for water to go around?
If so I can order the proper ones online, just didn't want to wait for arival.
Thanks for advice,
-David
07-19-2005, 08:51 AM
NIce job, but a tee with a drop ear elbow above it and one below it would have done exactly the same thing and been a lot easier than making the loop.
Mr. Overkill
07-19-2005, 11:25 PM
I only did the loop because moen specified it in the install specs.
-David
Mr. Overkill
07-20-2005, 10:40 PM
HJ-
Are you saying that the loop is worthless the way I did it (drop L's instead of drop T's), or I just could have done it your way also, or your way is just as good as a loop with drop T's?
I'm confused.
By the way I reconfigured piping systed so I don't need to use the soft copper.
-David
07-21-2005, 08:14 AM
When Moen recommends a loop, they are referring to one that basically circles the shower area, not one localized like yours. If you wanted to get "picky" that loop, because of the extra pipe and fittings, could have a lower flow than the one I described, although you would have to have very precise instruments to measure the difference.
Mr. Overkill
07-22-2005, 07:49 PM
HJ-
Here is a copy of the design guide I went by. I went by the picture, to late now. :confused:
The fine print to the left says "A pressure balancing loop must always be used with body sprays to allow for equal supply of water to each spray".
Here is also a link to pics of my final plumbing posted on a thread at John bridges site.
-David
plumguy
07-22-2005, 08:06 PM
Always follow manufacturer's spec's just like you did! The job looks good, I only question why you used drop ear 90's as opposed to 1/2c x 1/2 f tee's. It would make the pressure loop more balanced as shown by moen.
Installing a drop ear above and below a tee is just plain bad advice!! You'll be glad you did not make that change! Whenever someone wants you to go against manufacturer's spec's have them prove it! Chances are, you'll never see any proof!!
Mr. Overkill
07-23-2005, 11:11 AM
Plumguy-
Thanks for your reply,
There is no supplier of that type of fitting in my small town. Would I be better off to order online and redo with the proper fitting or would the differance in balanced pressure so little it wouldn't be worth my sweat and heartache of redoing.
-David
plumguy
07-23-2005, 11:53 AM
You should call Moen and ask them!
07-23-2005, 05:22 PM
That drawing is a classic example of an engineer with a little knowledge and a lot of time on his hands. The ONLY time a pressure balancing loop has any advantage is when you make a feed connection to both sides of the loop, not to one side and make the water circulate through the loop. If you had several heads on the same circuit, but mounted on different wall, then putting a tee at the valve and looping in both directions so the feed supplies both the first and last ones would have been beneficial. Doing it Moen's way delivers absolutely no benefits and took more time and money. But since it does not create any problems and is done already, live with it.
plumguy
07-23-2005, 09:12 PM
I don't particularly care for Moen and maybe it has to do with their engineers having a little knowledge and a lot of time on their hands. I guess that is why they never put you on hold when you call the tech line trying to fix their junk! Maybe, they are hiring and you could turn things around in their design dept.
But, regardless of your'e knowledge do you think you should advise someone to adapt their installation away from the manufacturer's engineered design. You know just as well as I do that is a big no no! It voids all warranty and if you can't post your'e stamped engineered design as proof then I certainly don't think your'e ego warrants a change in the installation!
07-24-2005, 07:48 AM
It voids what warranty? And Moen puts me on hold many times when I need a part, usually a Monticello handle that had to be destroyed to unscrew it from the valve body, again because of some engineer's bright idea as to how to make a faucet handle.
plumguy
07-24-2005, 10:35 AM
Manufacturer specs override all codes(at least here in MA and our codes are pretty stringent)! If installation specs are not followed it voids warranty. If you install something that does'nt work properly and if a rep comes out to check it and it is not installed to their specs warranty is void. Believe me, I don't defend or as previously posted on other posts care for engineers. However, legally you can't change their design or product specs without approval regardless of your'e ability or experience. We don't agree or follow that all the time but when the sh@t hits the fan that's what it boils down to!!!
