View Full Version : Replacing Waltec Shower Cartridge
Hektor21
04-26-2009, 01:27 PM
Hi,
I have a leaking Waltec shower and have been trying to replace the cartridge. It is a single tap shower and I have stripped it down as far as I can get. I am not sure which part to remove next. It looks like there may be an outer metal ring or cover and although I have tried using grips to twist it off it won't move even though I have covered it in penetrating fluid. (I cannot see any screws that may be holding this ring/cover in place). I am concerned that if I apply too much force in trying to twist it off I will damage the copper piping in the wall and then I'll have a real problem. I have hopefully attached a picture of how far I have got.
Any advice greatly received.
Redwood
04-26-2009, 02:26 PM
That looks a lot like a Delta knock off...
The cartridge section may actually be connected to the rear portion with 3 small tubes which can break/shear very easily.
You cannot over muscle this with good results.
I would use a torch to heat the nut and it should come of easily then.
