Redesign Kitchen Sink Plumbing??
Rhino1
California
We have a double-sink (with garbage disposal and dishwasher) that continually backs up--on average, once every 1 to 2 weeks. The backup is on the garbage disposal side, which is the only side we really use. We plunge it, and then it's good for a week or two.
Our guess is that the design of the plumbing is bad, and the backup is at the T, where the two drains meet.
Can someone please give us some suggestions about remedying the problem. We've seen pictures of the ideal double-sink set up, but they really don't work for us because of the location of the horizontal pipe going to the drain. And we'd also prefer not to have rip everything out.
The sink picture is below.
Thanks in advance for your ideas.
There really is no love lost by cutting out the pipes pictured and starting over. Without getting overly complicated I would recommend either doing the necessary research and look at more pics of how undersink drains are configured or hire a plumber to make quick work of it.
The Badger 5 is the problem,the grinders are not as good as when it was new.
Now I know you do not want to replace it but that may solve your problem.
If you do replace it, a Pro Evolution, Insinkerator is the one to install.That is your best bet.
http://www.insinkerator.com/disposers/index.shtml
They no longer make the SS333
drain
That drain is almost guaranteed to stop up frequently, because there is NOTHING to induce the discharge to turn down to the trap. It will want to go straight across to the other side and as it builds up it will finally stop the drain. There is NO reason why it cannot be plumbed the conventional way. And in so doing you would eliminate a lot of unnecessary turns. How old is the disposer? It might also be time to replace it. They will operate a long time past the time when they should have been replaced.
The blue tint of the paint that disposer is a color which insinkerator has not used in years. It tells me that the disposer has a 99.999952345% chance of being shot and should be replaced. It is sending unground food down the drain. It died years ago and just doesn't know it yet.:eek:
Or this.
And Redwood is right. The blades quit slicing and dicing long ago.
There is no way you will be able to get those long slices down the drain with that old relic.
Really? Thats how most of the drain kits I've seen are designed to be set up, and unfortunately how mine is currently set up. I don't have any problems though.. Same setup except with a new badger 5.
When your vertical drain in the wall is smack between the two sinks, how can you plumb it like Terry's diagram or in the picture kingstoall posted?
With a fitting like a 45 or 90 you can move it almost anywhere.
You can use the tee in the middle, with a baffle, but how do you grade both sides down?
What you have, is a santee without the baffle.
You can do that, but a plumber wouldn't.
Our answers will reflect that.
I gotcha. Thanks Terry.
This makes me think of another question--What makes bathroom double lav sinks different in that they need individual traps then?
I've never seen a double lav sink with a setup like this. Usually they are trapped individually then combined with a horizontal wye.
Sometimes it's the distance but more often it's a matter of keeping as much usable space underneath for storage and drawers.
A double lav is considered two sinks where as a double kitchen sink is considered one sink.Different P/O and DFU.
Portant outlet fixture units.Lav 1 dfu k/s 2 dfu
drains
I NEVER install diposers using the supplied elbow for the connection. I ALWAYS go straight to the tee, except for high/low sinks configurations. This raises the piping to give more space, eliminates a joint which could come apart if someone leans on it, and makes a more direct drain. 1/16, 1/8, "Y"s, and elbows make almost any drain doable using the end outlet disposer connector kit.
