Toto Drake slow to refill
katydu2
Toto Drake Tank slow to refill
Let me first say that I LOVE my Toto Drakes, they've never failed us before. I first heard about them here about 5 years ago - Thanks! :D
We are in a different house now and just finished a remodel, adding two new Drakes. It is flushing fine, but afterward, one toilet does not immediately start the refill of the tank. There is a silent pause and maybe 15 seconds later, a loud hiss as the tank begins to fill. What can be causing this to happen? And is it a symptom of something worse to come?
Thanks.
(The Drake in our guest bath, used much less, is still fine.
We did however, have one connected before the demo and it too began this pause, which grew quite lengthy before the hiss and refill. At that time we ignored the problem distracted by other issues. We figured it to be a fluke, and that tank and fittings were ultimately replaced before the reinstall anyway.)
https://terrylove.com/korky/
Sometimes it will go away on its own. Depending on which fill valve you have, if it is the Korky one (no screw on the top), you can change the seal assembly in about 30-seconds. Lowes sells them for less than $3. Instructions are on the package. You could try taking the cap off and removing and checking the filter, but it's probably okay. Instructions are available here, burried in older threads, or check out www.korky.com.
