seanc
07-12-2005, 10:52 AM
Hi there,
i just finished the plumbing for the basement, everything went really well and looks fantastic. I put up the drywall before finding the answer to this question and need to figure this out before i finish painting it.
I am running the copper pipe through mainly wooden studs, it does however pass through some metal studs. I didnt use nylon gromets around the holes the copper is running through. Is this a problem? Do I need to pull the drywall down and redo this? I'm not sure if copper and metal studs will create an electrical charge and cause the copper to corrode.
Thank you for your time!!!
