View Full Version : old fashioned galvanized tub drain cleanout
danceswithhammer
04-15-2009, 08:37 AM
I have an old galvanized plumbing system with a tub attached to a drum shaped trap of some kind with a plug that unscrews mounted in the woood floor adjacent to the tub. I assume this is a p trap of some kind. It was probably installed in 1937. Should I keep this or figure out how to remove it and replace with conventional ABS p trap and new drain and overflow? The existing drain and overflow leaks, is corroded, and drain is slow.
SewerRatz
04-15-2009, 12:45 PM
You can change the waste and overflow with out the need to change out the drum trap. I keep the drum trap as long as the plug comes off and the threads in the trap are still good to make a water tight seal when the plug is installed. To clean the drain you remove the plug on the trap and rod the line back to the tube and towards the main drain, usually no more 10 feet away.
Gary Swart
04-15-2009, 05:49 PM
I agree with Sewer Ratz, but if you every do a remodel, get rid of both the galvanized pipe and the drum trap. Those traps are way outdated.
SewerRatz
04-15-2009, 06:34 PM
I bet you would say using plumbers putty to set a water closet is outdated too.:p
Redwood
04-15-2009, 08:20 PM
Who wouldn't!:D
Sewerratz. See what association with us is doing? You are getting smarter already.
SewerRatz
04-16-2009, 10:09 AM
*snickers* Hj I still use plumbers putty, I have a shelf full of 5 lb tubs of sta-put putty. I dislike wax, and really dislike them waxless set ups. Give me putty or a Zurn Neo-Seal or give me death.
kingsotall
04-16-2009, 08:30 PM
Bet you played with playdoh and silly putty when you were a youngun' too huh, ratz¿
cwhyu2
04-16-2009, 08:48 PM
Sta-put rocks,but for a W/C flange to W/C seal wax works the the best.
IMO
SewerRatz
04-17-2009, 07:25 AM
IMO
I have had troubles with wax in many places, where plumbers putty solved the problem. If you said that in front of my sponsor, he would of given you an ear full.
All the time. I loved the stuff. Also when I use to hang out with my dad in his work truck I grab a big ball of plumbers putty and play with it as well. The nice thing about a good plumbers putty is that it did not dry out like playdoh.
seattleplumber
05-28-2009, 10:45 AM
...without any real gain in quality. If a toilet is properly bolted and shimmed, wax will last for decades.
SewerRatz
05-28-2009, 06:59 PM
So will putty.
kingsotall
05-29-2009, 05:14 AM
I was asking another guy about the whole putty for setting closets and his take was that the putty would dry out and shrink. We see it all the time on basket strainers that leak.
SewerRatz
05-29-2009, 06:29 AM
I have pulled water closets that where set with plumbers putty over 10 years ago and they had perfect seals still. Thing is to use a non-drying putty. But if you think about it no matter what you use, wax or putty, over time it will degrade and need replacing.
