hhcibtpaun
OK, I promise, this will be my last post for the day
So, I am pouring the concrete tomorrow, and I had a question about a tub box. My original plan was to just fill everything with concrete. I have a glued in P trap, so that is pretty much not going to change. The tub shoe is a little below grade but I was going to create a little fixture to keep the concrete away from the shoe and overflow tube.
As I have been looking around this site, I have seen people building boxes and leaving all the area open under the tub. Is that necessary? If everything is glued, including the trap does it serve a purpose?
Here is what my plumbing for the tub looks like:
If building a box is recommended...is the red box large enough, or the blue?
Again, if it is not necessary, I will stick with my plan to create a fixture to just allow enough space so the concrete does not capture the tub shoe or overflow tube. If I do a box I may have to concrete in two steps. One to create the opening, then a second to concrete the floor of the box. Obviously it is easier to concrete everything, without the box. But if there is a compelling reason to build the box, I will do it.
Comments, as always, are greatly appreciated.
Thanks...Mike
Thanks...Mike
