View Full Version : Tub shoe gaskets...can I stack them?
hhcibtpaun
04-14-2009, 05:49 PM
Hey Everyone,
I had a general question about the gasket used between the tub drain and the tub (tub shoe gasket I think)?
I was dryfitting everything before I concrete everything in and in a steady state, my tub shoe is offset from the bottom of the tub a little more than I planned for. I have two of the rubber gaskets....can I stack them, or can I get extra thick ones? The one I have is about 1/4"...I think I saw 3/8" ones...but 1/2" may work better.
I am assuming stacking may be ok, since the interface to the tub will still be fine. I will use plumbers putty on the topside of the drain.
TIA...Mike
jimbo
04-14-2009, 07:25 PM
Stacking gaskets is never recommended. Very high chance you will have a leak between the two.
Sandpiper Plumbing
04-14-2009, 08:28 PM
Simple answer - NO.
It will leak. Period.
hhcibtpaun
04-15-2009, 04:20 AM
Sounds reasonable. I will just see if I can find an extra thick one.
Thanks...Mike
04-15-2009, 02:27 PM
You probably will not find a thicker one, but if the drain doesn't fit, the overflow should not either, if you preassembled them properly.That is why we use a tub box, and put the drain in place AFTER the floor is poured.
hhcibtpaun
04-15-2009, 07:25 PM
I found a 3/8 thick one that should work. I will check it before I pour the concrete. I have fashioned up a cardboard box, to act as a tub box. I figure I will fill it with stone to support it for the concrete pour, then remove the stones and cardboard after everything dries.
I should have thought of this before I glued everything, but I think I am in decent shape. If I have major issues I can always redo some of it.
Thanks for the info.
Mike
