View Full Version : Gas and water in a kitched remodel
Jeff1
04-13-2009, 11:14 AM
I'm doing a kitchen remodel and need to add a new gas line and water line for the stove and pot filler. So far, I have 1 estimate. After recovering from the shock, I have decided to get some more estimates. Before anyone starts to worry, I AM NOT going to play with the gas or water lines myself. I would like to get more information and I'm turning to the experts for help.
The gas and water are both accessible in the attic above the kitchen. The plumber I got the estimate from was talking about having to drill holes for the copper and using flex for the gas line. My questions are:
For water in the attic, does the copper run through the joists or can it go on them?
For gas in the attic, are there any issues with using a flexible line?
I live in California - home of the earthquake building code. I realize the scope of this job but just want to have the knowledge base to help make good choices with the professional that will do the work for me.
Thanks for your help.
Ron6519
04-16-2009, 07:41 AM
In NY you can't run flex pipe down through walls. It needs to be steel pipe until you exit the wall. Then you can use flex pipe to hook up to the appliance.
Your local codes dictate a course of action.
Ron
Jeff1
04-16-2009, 12:03 PM
Thanks Ron. I've got another estimate coming today. I'll keep my fingers crossed.
The flex pipe used in the walls is completely different from that used to connect from the valve outside the wall to the appliance. The installer knows the answer to your questions and should do it the proper way.
Jeff1
04-20-2009, 09:24 AM
Thanks HJ. Does the flex line hold up as well? This is a crawl space and occationally (hopefully never) is needed for access. I guess I'm concerned with someone crushing the line if they are working up there.
IT could be crushed if the worker were heavy enough and stepped on it, but most would be smarter than that, unless they were into sabotage. IF the connections are made so they do not leak immediately, there is no reason for it to fail naturally. Staples, nails, screws, etc., can damage it, but then I also had a carpenter drive a self drilling screw through a steel pipe.
Jeff1
04-23-2009, 10:37 AM
Just an update. I got a second estimate and it is much lower (about 1/2). Both are from licensed plumbers - 1 is a big company, the other is owner/operator. I'm going to go with the owner/operator. Who knows, I may be his gopher. Thanks for the info
Jeff1
08-24-2009, 11:35 AM
Got the work done. It looks clean and seems to work. Hopefully the gas is in the correct place for the range (that's being delivered today). The only glitch was the plumber sat on the ceiling dry wall and made a butt shaped hole in it. That was good for a laugh and since there is so much drywall work being done anyhow, its no big deal.
They used copper for the pot filler and flex (3/4" yellow) for the gas. The copper is attached to the joists in the attic and looks pretty good for the rest.
Thanks again for all your inputs.
That is probably the way I would have done it, except for the drywall damage.
Lakee911
08-25-2009, 09:36 AM
I would have run hard pipe .... I just don't like the idear of that flex in the walls.
Personally, if I was uncomfortable doing the work myself I would have done it anyways and THEN had a licensed plumber/pipe-fitter inspect and test it.
Jason
Jeff1
08-25-2009, 01:21 PM
I'm just glad he didn't charge extra for the drywall damage. As for doing it myself, I'm very comfortable with electrical, but don't want to touch anything that can leak in the walls or cause my house to explode. I'm kind of funny that way.
