View Full Version : Bradford white lowboy
Cybermonkey
04-06-2009, 11:40 PM
Hey guys,
I am in the process of getting ready to install a hot water heater. My idea is to install the HWH in a closet underneth a stairwell. The problem is my max height is 48". So, I am considering a Bradford White Lowboy 47 gal version. I have a wife, two kids and two bathrooms. I think I will get just enough hot water but am not quite sure. What do you guys opinion????
BTW, I have no Whirlpool tube or dishwasher.
Redwood
04-07-2009, 12:25 AM
Go to this link plug in the details and see what it says...
http://www.bradfordwhite.com/rightspec.asp
master plumber mark
04-07-2009, 05:07 AM
you are talking about a gas low boy, correct???
that will be more than big enough...
it will work fine as long as it is permitted to install one
under a stair well in your area..
and as long as it dont get starved for air.
I suggest you put it in a pan for the day will come
when it will go bad .
04-07-2009, 07:04 AM
It had better be an electric heater if he is putting it under a stairway. And the 47 gallon lowboy is equivalent to a 50 gallon regular so you should have no problem with it.
Cybermonkey
04-07-2009, 08:38 AM
It will be an eletric HWH. I will definitly take your advice and put a pan under it! Do they make a drain for the floor that acts like a check valve? The HWH will sit on my first floor above my crawlspace. If I had a drain to the crawlspace below I would be golden. Accept I am probobibly not seeing a code issue or two.
Thanks for your help.
