mlbauer
04-05-2009, 04:09 PM
in the spring of 08 i had an electric water heater installed...the idea being to turn off the boiler in the summer for domestic hot water (lookingf a $4 oil). When I turn the boiler on in October, I found back bedroom wouldn't heat. (ranch, one floor, 3 brms.). heating guy here at 9:00 a.m., left at 5:00 p.m and all he did was move the air block from backroom to front room. said he would have to return and tear out my (new) basement ceiling. emailed weill.mc. ,this is the answer i got back.
"What has happened is that when they opened the piping lines to install the electric water heater, air got into the lines. They should have bled at the highest point in the house.
If they did, instead of tearing up your ceiling, our engineers recommend you have an air scoop added to your system to eliminate the air. The contractor you choose to do this should call our Tech Service Engineering dept. to ask about purging air with an air scoop and Dawn dishwashing detergent"
next heating man looked at message, didn't (wouldn't) call and spend several hours trying to drain...still an air block.
i have spent close to $600 so far, and afraid to call anyone else. I tried purging air from blocked baseboard. Only cold water comes out. (wonder what happens at the boiler as I drain.)
can you suggest the next step. another tech who doesn't know what to do and spends several hours and several $$'s.?? anyone I call wil say $79 to come and LOOK and then estimate. The previous 2 did just that and couldn't fix it. Telling them they won't be paid unless its fixed won't work...they simply wouldn't come. And tearing out my ceiling downstairs is not an option. HELP.
