Toto Vespin toilets
betsycapp
What is your rating of the CST764SG? It is a little higher than the regular Drake. i prefer the look if the flushing is as effective, and I need a compact bowl. Any problems with that one? Any better recommendations?
I have a Vespin and have not noticed any problems in the 5-years or so it's been installed. Hard to do a direct comparison, since I don't use the Drakes I installed at my mother's house that often...my guess, is you'd not be dissapointed with either. I have a Carlyle in my second bath which also works well.
Toto Vespin II CST474CEFG with SS114 Softclose seat.
This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
Installation was by James Love of Love Plumbing & Remodel 206-949-5683
In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
Everything is on the truck for that.
The Vespin comes with a standard 12" adapter or you can order a 10" or 14" adapter depending on your rough-in distance.
Any Toto will perform well, so if the Vespin's appearance appeals to you, and it meets your other requirements for size, etc., then that will be a good choice for you.
