View Full Version : hot water build up in water system
DT plumbing
03-31-2009, 08:36 PM
Hello Everybody;
This Is Derryn the plumber with a question
I have a customer that has hot water build up pressure
I have installed a new PRV, The problem still exist
Should I install an Expansion tank on the HWT
I am wondering if this will stop the problem
dtvansickle@hotmail.com
Thanks Derryn
SewerRatz
03-31-2009, 08:37 PM
Hello Everybody;
Thanks Derryn
If there is a PRV on the system you must have an expansion tank.
04-01-2009, 07:06 AM
The pressure should build up in the entire system, not just the hot water, unless there is also a check valve on the line to the water heater.
seaofnames
04-04-2009, 06:00 PM
You are a plumber and you dont know you need an expansion tank after a PRV?
I'm sure you could have done some more trouble shooting before asking here!
