View Full Version : Tankless Water Heater for Tub
BlackNoir
03-24-2009, 11:31 AM
I posted this in the Shower & Tub forum before realizing there was a tankless water heater forum so I thought I'd try over here too.
Is it plausible to get a tankless water heater for a tub? We have a 50 gallon water heater and we never seem to have enough hot water for our tub. The tub holds ~90 gallons and it's not like we fill it with steaming hot water. The water heater is new so...
Is it possible to hook up a tankless water heater in series with the regular water heater as an assist?
Any other advice besides taking a cold bath?
Thanks,
BlackNoir
jadnashua
03-24-2009, 02:02 PM
Depending on how the pipes are layed out, it may be cheaper to put in a second WH rather than a tankless. Feeding warm/hot water into the tankless would decrease it's load and allow it to heat the water hotter, but at some point, you'd be restricted by volume...as the input to the tankless system gets colder, it starts to limit how warm the output is. Since you'd only get maybe 40-gallons out of the WH that was hot, you'd then quickly get down to your normal cold water inlet temp, and that's the thing that dictates the size of the tankless you need. The tankless would need some fairly expensive flue setup and you'd probably need to upgrade the gas line and maybe meter size. You might not need to do that with a second tank WH, depends. A tank has the luxury of taking its time to reheat, a tankless needs to be big enough for the maximum load, so the burner sizes are often quite different.
I think you'd be better off with a second conventional WH in series. It would have been better if you'd sized what you have to your needs, though.
gregsauls
03-25-2009, 02:11 PM
Taking the other side... I would add a tankless unit in this case BEFORE messing further with a tank solutions. For one easy, quick reason... unlimited hot water. Whether you fill that 90 gallon tub once a day or march the whole family through one at a time and only half fill it a tankless solutions will fill that need. You 40 gallon unit can't do that as you have found out and adding another tank will only put off the eventual lack of hot water each day.
I use a tankless unit every day and have not had a single negative issue nor has the family complained... and they would! My unit was installed in a house with 40 year old plumbing so "pipe issues, routes, location" have been overcome or non-existant.
nhmaster
03-26-2009, 05:24 AM
And here we go again ! :mad:
SewerRatz
03-26-2009, 08:00 AM
Just did a job yesterday, guy called me and begged me to remove his tankless POS and install a 75 Gal Power-vent. He had nothing but troubles from the start. The tankless unit was 2 years old had to be delimed every two months, even though he does have a water softener in working order. Had to have the heat exchanger replaced twice, also if more than one person in the home ran hot water is flow would turn to a trickle. This unit is designed to reduce the flow rate to ensure you get the 120° water temperature. He can not afford to run three units which would handle the demand nicely. Upgrading the gas line is the biggest issue, since adding two more units would be putting a 400K BTU load on his gas system.
The moral of this situation is only install a tankless system properly sized to handle all your needs with in the home, and plan on doing maintenance on the unit on a regular basis. Remember you are cooking water really fast in these tankless units so they will leave lime and other minerals deposits in the heat exchanger, look at what happens to a pot when you constantly just boil water in it. Also there is no Anode rod (known as a sacrificial rod) for any impurities to attack, so they will attack the heat exchanger and will cause leaks. Takagi just announced it has came out with a a TK-3 Pro, the difference is the copper alloy it uses for the heat exchanger they call it HRS35 copper alloy, for the heat exchanger tubing In their own ads they say it will resist getting pin hole leaks like the standard TK-3 unit. They know there is this problem but of course none of them will advertise that fact. Just like they do not advertise the fact you need to delime these units regularly.
gregsauls
03-26-2009, 12:07 PM
Maybe a preface is needed regarding my positive post! Geez
IF, big IF, your water is a problem (pressure, quality etc) then a tankless will not work for you long term and the above begging to have it removed MIGHT apply to you! No if, ands or buts....
I, real world everday user here of a self installed tankless unit, love my tankless system and will not have it removed as I don't have the problems that a few people on here seem to want to continue to scare people with horror stories. My use of a tankless is a fact and of course this scares the crap out of some on here as they can't see to handle the concept of anything other than a big frikin' tank wasting away in the basement and that future revenue stream of $500 to replace it when it rusts out yet again. FUD.... google it.
In MY CASE, regular maint will be a ONCE PER YEAR descaling of about 15-20 minutes of my time. No biggy.
Ladiesman271
03-26-2009, 01:38 PM
Maybe he should get rid of the water softener instead!
From a water softener web site:
"SALT IS CORROSIVE
Those in The Navy are familiar with the term "Marine Whites." Sailors used to put their white clothes in ocean water to whiten them. Caution had to be used because if the clothes remained too long in the heavily salt-laden water, they would deteriorate. Salt is corrosive. Softeners use the same salt spread on icy roads, which destroys the underside of cars. Those living near oceans know well the corrosiveness of salt to cars, houses, etc. Many people with galvanized pipes found that salt softened water did prevent scale build-up, but the trade-off was the salt also corroded their pipes.
Homeowners with salt water softener systems will go through more water heaters because of the salt's corrosive effect on the heating coils. Always check with a manufacturer's warranty related to water. Softened water should not go to a pool or spa. Hard water and naturally soft water have their maintenance issues, however softened water offers potential problems that may imply or outright void the warranty on certain products."
chris8796
03-26-2009, 03:14 PM
99% of real world everyday users are incapable of installing a tankless or tank WH and have minimal understanding of plumbing systems. I'm sure most plumbers would rather make their money carrying a tankless unit down the basement, than drag a 75 g tank down the stairs. So I don't think money alone is motivating their opinion.
For the real world everyday user, that means paying a plumber to do this (long after it would be considered preventative). So if you need a plumber for your plumbing needs, you should listen to your local plumbers' advice and what they are comfortable working with.
For the OP, I would go with a tank or a tankless solution, not a hybrid. Both offer solutions, but only a local plumber can tell you what each will cost and what they warranty. If you had real qoute numbers it would be easier for everyone to offer real world advice. This sounds like a good application for tankless, but if your local plumbers don't like them (for whatever reason), you will pay a steep premium to install and warranty one.
nhmaster
03-26-2009, 03:19 PM
Thanks,
BlackNoir
Yes it is possible. However, if you do a little bit of thread searching on this and other sites, regarding tankless water heaters, you will soon see that the majority of professional plumbers, guys that deal with these things day in and day out in many differing scenarios are not particulary impressed with them. Then you can come back here and read the unrealistic glowing praise of them from our two in house protagonists that are under the impression that their opinions are somehow more valid than those of professionals. Tankless heaters are a complete waste of money and nothing but a service nightmare from day one.
SewerRatz
03-26-2009, 05:11 PM
"SALT IS CORROSIVE
OK then lets void the warranty on 99% of the Tankless water heaters They say they will not honor the warranty if the water is to hard. I am not trying to scare anyone away from a tankless system. I just want them to know they need to size it properly and understand it nothing like a tank system where if you do not maintain it will just cost more in fuel and will leak sooner. Tankless if you fail to maintain them you stand the chance of leaks but first thing you will notice is a drop in water flow. Rinnai has a nice added feature it will tell you an error code of "DL" when it is time to delime it.
Oh back to sizing the tankless system someone in one of the posts said a single unit works just fine for them since its just 2 people living in the home. Here is a little blurb from Takagi's website "Remember: Although a home with two or three bathrooms may only have one or two occupants currently, the number may increase if the family changes or the house is sold. Size for the house, rather than the number of occupants." They as well ANY of the other tankless manufactures tell you to size for the house not the number of people living there. It was the mistake my customer with the "begging" me to remove his tankless did. He tried to go about it on the cheap-side and use a single unit in his 3 bath home. He said he was real happy with it the first year it was installed other than the deliming part. But when his kids moved back in and they tried to take multiple showers at once the water pressure on the hot side went down to a trickle. Yea they where getting 120° water temperature out of that trickle. The fix was to add at least one more unit to handle his demand but another 200K BTU demand on the gas would mean the gas meter needs to be upgraded and the pipe coming into the home up-sized. To solve the problem where he can use water with all 3 showers and a dishwasher he would need 3 units to handle it, or replace his first unit with the commercial model and install the second commercial model.
He did call me today his kids where in two of the shower and he was in his master bath shower and they all enjoyed a good shower at the same time for the first time since the kids came back home.
Oh for those of you wanting to install a Tankless water heater yourself, get a brand that does not require a licensed plumber as well as having to take their training class. Other wise your warranty is void.
Redwood
03-26-2009, 07:30 PM
PFFFFFFFSSSSSSSSSSSSTTTTTT
http://i44.photobucket.com/albums/f2/Redwood39/troll-01.jpg
Looks like our 2 favorite tankless trolls are back again....
At least your avitar speaks the truth...
http://www.terrylove.com/forums/image.php?u=30289&dateline=1235749589
Now if only we can get laddie boy to pick one that fits...
ChuckS
03-27-2009, 01:08 AM
But when his kids moved back in and they tried to take multiple showers at once the water pressure on the hot side went down to a trickle. Yea they where getting 120° water temperature out of that trickle. The fix was to add at least one more unit to handle his demand but another 200K BTU demand on the gas would mean the gas meter needs to be upgraded and the pipe coming into the home up-sized. To solve the problem where he can use water with all 3 showers and a dishwasher he would need 3 units to handle it, or replace his first unit with the commercial model and install the second commercial model..
Seamed cheaper to tell the kids to shower one at a time. That's how we did it growing up and how we do it now. Even with a tank heater, with multiple showers going on, you will have to be quick or the hot water will run out. For the life of me I can't imagine the need to run 3 showers and a dishwasher at the same time.
SewerRatz
03-27-2009, 06:52 AM
3 showers, dishwasher, washing maching.... Its hard to tell everyone they need to get up an hour earlier so they can shower one at a time. They all already are up at 5 am and out the door by 6 am to head to work or school.
gregsauls
03-27-2009, 07:37 AM
Consider the above source. An out of touch with the real world "old school plumber". Probably just grasping the concept of indoor plumbing. :eek:
Sorry to inform ALL, no problems with my tankless from day one. I know thats hard to grasp for the "old schoolers" on here.
gregsauls
03-27-2009, 07:54 AM
...It was the mistake my customer with the "begging" me to remove his tankless did. He tried to go about it on the cheap-side and use a single unit in his 3 bath home.
In all my years of customer service and support (25+) there always seems to be what I call "the rest of the story". When a system is down the blame is placed on the equipment as inferior or defective in nature. It's only after the tech arrives and starts digging into what is wrong that "the rest of the story" comes to light. The customer did "xyz" and the system overloaded and/or failed.
Whether it's plumbing, heating, a/c, doors, windows, appliances etc they are "man made" and can be "man broke" whether intentional or through neglect.
I've stated before that to live in this technology rich world it will start requiring a person to know more about technology. If you have know how to keep the virus updates current on your PC then you should know how to call the tankless tech to delime once a year along with all the yearly routine house maint items. Better yet, let plumbers put in place a yearly call system for delime service for customers. Great revenue stream for scheduled service.
SewerRatz
03-27-2009, 08:13 AM
Greg, I do not mind installing and maintaining Tankless heaters, It just that many people think they can go out and buy a Tankless heater and have it quickly installed in the same spot with the same gas piping and exhaust venting that the old tank heater, which is not the case at all. A new install of a Tankless water heater needs to be sized to the max demand of the house per what every tankless manufacture says. Then need to ensure that the gas piping is sized properly to the heater and the gas supply is large enough to handle the total BTU demand of the Tankless system, furnace, and any other gas appliance. Then the exhaust venting CAN NOT tie into the same spot as the old water heater or go into the chimney, It needs to be vented through the roof or to an outside wall. Everything I just stated is a fact of installing a Tankless water heater system.
If you have noticed I keep saying "Tankless Water Heater System", I say this to cover the fact that there might be more than one Tankless Water Heater needed to meet the needs of the home.
Chucks let me point you back to what Takagi has to say "Remember: Although a home with two or three bathrooms may only have one or two occupants currently, the number may increase if the family changes or the house is sold. Size for the house, rather than the number of occupants." So what may work for you and your family might not work for the new family that moves into your house.
gregsauls
03-27-2009, 08:53 AM
Ratz... great points on what it takes to properly install a system. I did my homework which is why I am not having problems with my "tankless system." I, and many others, just get sick of the "I hate tankless/technology" crowd that seems to poopoo anything they don't feel comfortable with installing.
Brings to mind the phrase, lead follow or get the hell out of the way. Seems like technology may be pushing some aside.
jadnashua
03-27-2009, 10:58 AM
One big problem is that people often get glassy eyed when someone tries to tell them the facts, and then they see the costs, and believe they can do it better than a pro, or know better. I don't think there's anyone here that doesn't believe that a tankless system CAN work, but that many installations DON'T work well because of one factor or another.
There are situations where a tankless system needs enhancements to handle things a tank type does very well - take the example of a washing machine that fills and operates by short draws on hot water in another thread. The more complicated, the more maintenance and costs. Most people don't like compromises, and this means taking a shower when they want, and not having to wait for others...why have 2-3 or more bathrooms in the house if you can't use yours when you want? Sizing a system to support all users (and that is the code in many places) means (often) a pretty big inital cost.
Last thing, while a tank system should be drained, and with the new technology, the filter screen cleaned off regularly, many people never look at it after installation and it lasts many long years. You cannot do that with a tankless system. And, yes, you can get a tankless system to produce essentially unlimited continuous hot water if you size it properly. Most people don't want to do that either because of the costs and accept the limitations.
As to costs, standby losses aren't all that huge on a tank system, and the difference in equipment and maintenance costs plus installation on a tankless system, at today's energy rates, will likely make a tank system cheaper. A fairly typical tank system could be replaced 2-4 times over the cost of one tankless system. Plus, you can likely get your tank system replaced or repaired on a weekend, whereas trying to get a tankless repaired on a Friday night so you are not without hot water for the weekend or longer has a much lower probability of success.
I think many of the pros don't want to install tankless because people don't want to pay for a system that actually has the capacity they really need, and the installer doesn't want to deal with an unhappy customer.
As I've said before, you can get a tankless system that will work well, but, at least in my mind, it isn't worth the cost in most cases.
gregsauls
03-27-2009, 01:16 PM
Dude, your were doing so well with your post until that last line and then you blew the credibility you gained prior. Change the word "most" to "some" and you might be back on track. Speaking as someone who owns a properly sized tankless unit operating in the southern states (warmer inlet water temp), with a properly sized gas line, no water hardness issues, no well, and who understands the maint issue says; it can work for many single family homes in the southern states when these conditions apply and probably a "few" north of the MasonDixon line too. That a LOT of homes and breaks the use of the word "most" in your above comments.
Does it cost more than a tank, yep. Does it save money, a bit. Will it pay for itself over 10 years, not without IRS tax rebates ;) Do I have all the hot water I want... YOU BET and that is a big win in my book.
Broad generalization by a few on this tankless sub-forum is what kills it's ability to be taken creditably and provide quality info for those posing legit questions and that a shame. I would suggest killing this tankless sub-forum off as it really is just a war between those who understand and use a tankless system daily and those who can't or won't accept a bit of technology.
It's getting like the old man driving the horse and plow, seeing the tractor for the first time.... You can only imagine the flow of obscenities spewing from him while he ridiculed the infernal mechanized beast.
nhmaster
03-27-2009, 02:44 PM
Greggy boy, you really need to do a bit more homework before you begin spouting crap. But yes, when it comes to new school crap I am definatly "old school" We have no problem with your devotion to your tankless heater. In fact I believe that it works just super for you, because you are more than willing to overlook and justify the money you wasted on the thing just so you will not have to admit it was a total waste of money and time. The cold hard fact is that the average gas savings is about 4%. You get stacking and you get delay and you can not operate every fixture in the house at the same time at full capacity. Anything you spew to the contrary is crap. I know it, you know it and the tankless manufacturers not only know it but are willing to admit it. Let's get back to your insult. READ MY BIO. Take a plane trip on up and have a look at my classroom. I have condensing oil and gas equipment, solar, ground water and air to air heat pumps, all the latest bells and whistles including a Rinnai a Tagaki and a noritz all hanging on the wall and operating. All of this equipment is installed, tested and torn apart frequently. I have the facitities, the equipment and the budget to do things that would make your head spin. You think I pull my critisism out of my ass because I have a vendetta against new technology? MY JOB IS NEW TECHNOLOGY. But just because something is new (and tankless heaters are anything but new technology) does not make it good. I can give two reasons to install a tankless over a high efficiency tank type heater and both are kind of lame. Number 1 would be space and number two would be...... Oh hell, there is no number two.
gregsauls
03-27-2009, 02:54 PM
Hehehe... I don't even have to read the above, since the yaahoo is blocked by me and should be by all others, and I smell BS flowing deep!
nhmaster
03-27-2009, 03:24 PM
A shallow attempt my friend. We all know you "read the above" and have nothing but wet ammunition. :p
ChuckS
03-27-2009, 04:31 PM
I hear ya, I guess I grew up in a time when no one did anything while someone was in the shower. No toilet flushing, no drink of water, no changing the TV channel, no nothing... There were 6 of us and we did it every day.
Dishwasher was turned on at night before we went to bed and clothe were washed all day on Saturday.
Also, I wouldn't spend a nickel increasing the hot water capacity for the new family. If they want more hot water, well, it's now their crib which comes with the pleasure of paying for what ya need... Ya know?
If they want more they can buy more.
