mgcpro
- Messages
- 2
- Reaction score
- 0
- Points
- 0
Help! I installed a compression fitting shut off valve for the bathroom sink and it's leaking. I tightend by hand then turn 1/4 turn, and probably turned a full turn, but it's still leaking. After removing the valve I noticed the copper pipe is slightly dented, which I'm suspecting is the causing the leak. I've wrapped teflon tape over the copper where the compression ring sits then re-installed the valve. So far it hasn't leaked. Is this a safe fix? If not, does anyone have suggestions on what I can do to fix the leak? Thanks!
