SteveSmith98
03-23-2009, 06:07 AM
Hi,
I'm going to be replacing my alcove-style tub with a different alcove style tub.
I plan to install a tub without an apron, and then tile an apron myself. This is so I can make all the drain connections from the side of the tub where the apron would be. I don't have access from below.
My question is about the waste/overflow connection to the drain/P-Trap. Specifically, how do they connect?
I would have assumed that I'd use solvent to permanently connect the two pipes. But, I've come across suggestions that a slip-nut (Is that the right term? The compression joint that connect to my sink drain basket to it's drain) or even a flexible coupling could be used.
What's common? What's recommended?
Once it's connected, it'll be sealed up with no access panel. I'm surprised I could be allowed to use anything other than a permanent bonded connection. I'm in Ontario, Canada for code-purposes. Existing drain plumbing is all ABS.
-Steve
-Steve
