Static interference from flourescent lights.
Giles
Retired tool & Die and Mechanic
N.W. Alabama--Florence--
I have several florescent light fixtures in my shop. When they are on, I get a lot of static on AM radio stations and sometimes on FM stations.
Why do they cause this and what can be done to correct the problem?
I got this problem too but my guy who does all my sound system stuff told me it's inevitable.
They make suppressors but he said the most of the time they don't work.
Those lights that operate off an electronic eye are the worst.
Have the receiver far away enough from the lights that there is no noise and run speaker wire to a speaker in the room...
cheap fluorescent ballasts....aka "shoplights" will have more interference.
You can try replacing the ballasts, and if they are not already electronic, switch to an electronic ballast.
Every light in my house is now flourescent, and we do not experience any ill effects.
BTW, get rid of any dimmers, electronic light timers, or motion controls. These are more likely to cause interference.
To cure these problems follow these steps
Step 1 – Using a 22 ounce framing hammer strike the radio firmly several times
Step 2 – After striking radio several times, using a broom sweep up broken parts.
Step 3 – Place radio in a container large enough to hold all the shattered parts and set in place
After following these three simple steps there should be no more problem with static noise from the radio.
Flourescent lamp fixtures just plain make a fair amount of noise in the AM band - especially if they have starters. CFL bulbs are usually better. Most motors are also noisey in this band.
It could be getting through the power...is the radio powered by cord? If so, is it on the same circuit as the fixtures?
If not, it may be pretty difficult to get rid of the rfi.
With tv antennas, I just make a braid breaker...but thats another frequency.
Does the ballast say "For commercial use only"?
This is why they say that...
