View Full Version : kitchen faucet holt & cold water shuts off
terri
07-05-2005, 07:52 PM
Our house was built in 1956 with galvanized pipe. We've slowly been relacing it with copper as the sediment causes problems. A couple of years ago, we replaced the hot water heater which in turn, jerked some crud loose in the pipes and we ended up needing to run a new copper hot water line to the kitchen. A few months ago, my kitchen faucet started acting up - the sprayer wouldn't shut off or, when using the tap, the water would switch to the sprayer or just shut off. I read that it might be the displacement valve so I removed the sprayer and capped it and all has been well. Last week, the water started to run a little slow, so I cleaned out the aerator and it worked until the end of the day - and the water whether hot or cold runs slow, then you can hear and feel a slight bump and the water quits. I'm trying to figure out if it's a pipe problem or maybe an old faucet problem. We have great pressure and no other issues throughout the rest of the house. Also - no problems with the laundry which is directly beneath the kitchen. A faucet problem, I can tackle - but a pipe problem requires a professional. Please let me know!
Thanks
07-06-2005, 06:35 AM
You capped the sprayer but apparently did not remove the diverter that made the spray work. It is still in the faucet and will still cut off the flow to the spout if something actuates it.
terri
07-06-2005, 06:46 AM
thank you! I'll get on it today.
terri
07-07-2005, 06:27 PM
thanks again - I took the opportunity to upgrade my faucet and everything is running smoothly again. :)
