I have a outdoor faucet leak on my house. Actually it is now all 3 of my outdoor faucets. The visible issue is nothing leaks until I turn on the water,and the leaking is occuring behind the wall,whether it be the garage floor,the front of my home ,or the adjacent wall. No leaks outside or inside when the valve outside is in the off position,but turn either three of them on and you can see water start to run from below the structure closest to it. There is a vacuum breaker(I think that's what it's called)on the faucet. Can anyone tell me what might be the problem. Remember it only leaks when I turn the knob to the on position,and I can clearly see water coming from my structure. Not a small leak, a small stream.
